2G Wiring Mishimoto Radiator and Fans
PatricksDSM
Jan 14, 2010
Las Vegas, Nevada
I have put the Mishimoto Radiator in but have run into a problem.. The new fans come with only 2 wires, and the wire harness from the car has 4. Does anyone know which of the 4 wires to use to connect to the new fans? Also, will the fan come on with the signal from the computer with only 2 wires connected, or is there a wiring secret? Thanks, anyones help will be appreciated!!
this is for 1990-98 talon/laser but might help, from the ignition on the run postion a black with blue stripe or black with stripe splices off into blue with red strip goes into the fan hi and fan low relays after fan hi a green with orange stripe goes to pcm and the other is white with the abreviation of L on the schematic not sure what color that would be but that goes to the fan motor that is those 2 out of the fan hi now the fan low has a white with blue stripe that goes to fan and the other is green with brown stripe to the pcm. if the helps.
