ECMlink Wiring AEM wideband with DSMLink
Hiitman
482
4
May 12, 2004
Colorado Spring, Colorado
whats the easiest way to wire these two together and where have people tapped for the wideband sensor?
Try the dsmlink forums. That's what the forums is there for. You'll probably want to wire the wideband into the rear O2.
Yes you wire it into the rear O2 sensor pin the ecu using the 0-5v output wire, or you can use the MDP sensor on the intake manifold ....but I would save that for a GM 3 bar map sensor.
The new cool one is the 3.3bar duramax map (GM part#: 9373269) and Cadillac wiring harness (GM part #: 88987997).
100% want to wire in a wideband into the rear o2 pins going into the ECU. Some people have even taken it a step further and installed a toggle switch for the rearo2 and wideband. Leave your MDP sensor for the MAP.
