AEM Wideband Datalogging Setup With DSMlink
sbeck
171
May 15, 2010
Hemet, California
In the instructions for the AEM wideband it says that there are two wires that need to be connected to ecm inputs for datalogging. If I were to install to the rear o2 ecu input 75 would I just connect the white (analog output +)? Do I just leave the brown (analog output -) disconnected? I can't see anywhere that it is explained where to hook the brown wire. Do I need to repin at the ecm or can I just use a butt connector on the wire already coming from the ecu?
I figured it out. It is just connected to ecu ground so pin 92 on a 2g.
