Wire Cleanup/ rewire
clipse4u2c
47
Feb 10, 2008
Hebron, Kentucky
Well, I just pulled the motor in the gst and I am going to be cleaning up some of the wires i don't need. My question is should i remove them completely at the fuse box (and if so how would i do that ) or just cut the wires right at the fuse box? your thoughts.
the only problem with cutting them would be leaving a live wire hanging there, i would just remove them completely. you might have to unbolt the fuse box from its brackets and lower it down a little to expose the back of the panel and pull the connector out of the box with some pliers. also everything you remove pull the fuse for that item to. but before do any of this disconnect the battery
i was just wondering what wires you are talking about removing or are you removing a/c or something like that to free up the wires for removal
well the motor is out and everything pretty much is out of the car. I'm doing a complete overhaul of it suspension and all. I already have the fuse box back cover removed. I haven't made a complete list yet but i'm thinking i'm going to remove the cruise even though I love it! Since I like it i'm going to leave the wire for it I think in case I change my mind. I'm leaving the A/C. I would love to remove it but 90+ weather sucks with no a/c. I'll get a complete list soon and i'll post it up!
