Wiper fluid hose routing, where?
S_Ranger
Banned Member
761
6
Aug 30, 2004
ca, Central America
I found that my hose is cut off from the rear. Next to the left tire to be exact. It's a clean cut but I can't figure out where it routes to. Looked in the manual and all I can find is "how to replace wiper blades". I look under the hood and see it routing from the hood itself, under the fuse box, through the firewall. Anyone know where it goes after that? thanks
Is it spewing wiper fluid when you try to use the washer? If it is then I'll try to look deeper, but when I had my interior apart there are a few drain tubes in the rear that lead to nothing, just drain. Pics would help... :thumb:
Man, I thought that hose was it too. Wiper blades work perfect. It's just the fluid that doesn't come out at all. I put in fluid in the the resevoir under the hatch and it just leaks out. That hose that is "cut" is directly under that resevoir. I can get pics but it will not be until tonight.
I think I found the problem LOL. I put it quite a lot of fluid and it started draining like crazy. There's a cap missing. It's under the trunk. There's 2 caps that should be in place. Now I remember you said things are missing or cut off for a reason but is this intentional?
