1G Windshield Wiper Trouble
arctic1250
Sep 28, 2010
Queen City, Texas
I'm having trouble diagnosing a problem with my windshield wipers. They don't work. I've checked the motor and it's fine. The fuses are all fine (I know because I've pulled all of them twice to check). Any help would be greatly appreciated.
are you still having problem with your wipers not working? and if so i would check all the wiring to the motor itself,otherwise using a test light or a voltmeter to make sure you have good ground or have power getting supplied to it.
Sorry that I haven't posted in a while. My psp got stolen and I didn't have any other way to get online. Yes, I do still have trouble with it and am not getting power to the motor.I'm starting to think that it is the switch because I am getting some voltage to the switch but none to the other end.
It could also be the wire from the switch to the wiper motor. Unless you mean that you checked voltage directly from the switch terminals then yes, its the switch
Try a continuity test at the switch to the motor. If there is I finite resistance there is a break in the wire. I'm not positive if there is a relay for it but if there is, have you or the mechanic tested for proper operation of it?
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
