will this NT head work on my turbo engine
shawny2087
75
Apr 15, 2005
milwaukee, Wisconsin
i need a new/used head dues to a lifter sticking and the #3 piston breaking off a intake valve which put 3 holes in the piston and ruined the head. i can get a head for $125 with 20,000 miles on it but will it fit my late 92 talon AWD tsi turbo? heres what its from 1st gen 93 Mitsubishi Galant. 4G63 2.0L DOHC non turbo. will the non turbo head work with my turbo? are the cam shafts the same? if not i have 6 shafts sitting around here from turbo heads thanx
The head will work if it is non turbo.You just need to pull the plug where the turbo oil line goes to the head and get the banjo bolt for the turbo.
Mike :talon:
okay souns easy enough. but are the valves the same as a turbo head and the cams? also is there just a plug is it alreadt threaded like the oil galley plugs? thanx
