will a turbo 4g63 head work on a n/t engine?
tmicah
Aug 16, 2010
Dayton, Ohio
hey i found a non turbo laser 4g63 for only 200 bucks and all it needs is a new head. theres no lower end damage. will a turbo 4g63 head work with the non turbo engine with no problems???WTF
It will work problem free as long as the turbo head is from a 1990-1994 car. The camshafts are different between the two, but you should be able to use either pair.
YES... It will work. But you need to know what year engine you have and what year head you have. 7-bolt bottomend used 11mm head bolts. 6-bolt used 12mm head bolts.
well the engines out of the 91 laser, but i have not a clue what year the head is. i bought it refurbished and redone with all new valves rockers springs etc
If the head bolts fit through the head you should be good to go. Also make sure you plug the turbo oil feed hole with a bolt and a copper washer.
