Will a NA head work on the turbo motor?
yes the heads are the same... the cams are diffrent tho
check the head bolt holes tho, depending if you have a 1g or 2g. the 2g have smaller head bolt holes but can be reamed out to fit on a 1g
As far as im aware the heads are identically the same. The NA intake cam is different though so I would swap it out with a turbo cam. Exhaust cam is the same though.
