Will a regular head work with a stroker motor?
DeadsEvolution1
357
Jan 10, 2008
Albuquerque, New Mexico
will a Stroker block work with a regular head?? The head just had new valves put in but thats it. So I am wondering what the draw backs would be with this?
I am going to be running a small 16G, 660cc injectors, walbro 190 fuel pump, NGK Bpr6 spark plugs and wires, FMIC with HKS SSQV.
To get list is a eprom ecu, 2G Maf, DSM Link, and a fuel pressure regulator but for right now I can only get the motor.
Any info would be great
The regular head will be fine with the stroker.
However; keep those 660cc injectors on the shelf until you have some fuel control installed.
i currently am running a stock valve train (minus 272 BC cams) and a non-ported 6bolt head with my stroker. You'll be fine.
A lot of people do stroker with stock heads even on the evo side. you should probably put an afc on the front you your to get list. you can find used ones pretty cheap.
