will this fit on a t-28
yes it will. it has the same mitsubishi flange. you will want to port your t28 exhaust housing to match the size for best results though. other wise, its pointless to add that and all the exhaust flow gets choked at your inlet anyway.
talk to KENAMOND, that guy knows his t28 porting.
he also goes into porting the stock 2g manifold. its the same size runners just a smaller collector than the 2G.
Good luck!
Im not exactly sure if it will fit or not but for a t-28 you can get the same performance from a ported 2g manifold. It would cost you less, look the same and most importantly have the same performance.
I have the same GT manifold and it fits perfect, like everyone has said ^ you will have to match the hosuing. I bought mine from DSMparts.com but its the same thing. The turbo bolts included did not fit with mine because they are not long enough so you will have to use what you have. I would say it flows better than a ported stock 2G about the same as a ported EVOIII manifold. My stocker cracked so I bought this one.
