Will This Fit
DearestNameless
308
Jan 16, 2010
Linton, Indiana
2.5 Turbo Elbow
2.75 Downpipe
2.375 High Flow Cat
2.5 Catback
All this is suppose to bolt on. All gaskets and bolts included. What are your thoughts? Will it fit together? Does it sound ok?
Thanks ahead of time. :)
Just go with either 2.5" or 3" the whole way depending on your goals. The o2 housing will usually be a 2.5" outlet and most downpipes will be flanged at 2.5" and enlarge to 3".
I would go 2.5 all the way but I already have the exhaust and downpipe. The turbo elbow is 2.5 anyways. So I guess all that matters is if the 2.75 will fit the 2.375. That is the biggest jump. I eBay'd most of it. =/
Exactly. It's really cheap to do a setup like this. Evo3 o2 housing is one of the more reliable to go with. Ebay downpipe. Test pipe or a Cat. My preference is both so you don't kill the cat. Just toss it in when inspection time comes around (if you have one). Then the catback is all up to sound preference. Fin.
And now I have an urge to go watch some "Will it blend" videos haha
Mmmk
Just bought the rest of it
2.5 Elbow
2.75 Downpipe
2.5 Testpipe
2.5 Exhaust
Already had the downpipe or I would've went 2.5. :(
Thanks!
Mmmk
2.5 Elbow
2.75 Downpipe
2.5 Testpipe
2.5 Exhaust
Thanks!
I'm more than 99% positive you'll have to take it to an exhaust shop unless you have welding equipment. Taking it there they will fix the fitment issues you will have and clock all the flanges properly if they need to be done.
If anything, they may weld on a reducer pipe to the 2.75 DP depending on how much flange space you have.
  • Wanted 6 bolt NT water pipe
    • chrisman287
