Will these rims fit with spacers?
atownturbo
230
May 21, 2008
Reno, Nevada
Ok i know that the lug pattern is different(5x112) but i decided to try it anyways. They go on just fine but it starts to get tight the closer it gets to the caliper. I was just wondering if i put a set of 24mm wheel spacers in between the rims and calipers if it would be bad? Or if it would be the same as putting them on 114.3s?
I like them.
Don't do it. You'll break wheel studs in the very least.
+2 like he said you'll break the studs..Let me tell you something..I have broken wheel studs before,, not something you want to have happen.That was pretty much the worst day of my life..I was lucky and only broke the wheel studs, a messed up fender, and broken side skirt..
