Will Speed Density Tune Change With Warmer Weather?
stroh
84
5
Oct 17, 2002
Freeport, Illinois
I had my car tuned professionally by Boostin Performance back in October. It was probably 55-60 degrees outside. I'm new to speed density and I was wondering if the tune will change much when I drive the car and it's 85 degrees out. I would imagine the idle and cruise might not change much, but what about the WOT? Any help is appreciated. Thanks
I had to take my car out a few times last year to make some small adjustments with the weather changes. Is it "necessary", probably not. Most of the adjustments I had to make were when it was getting cooler and was having some issues starting with e85. Adding a little fuel during cold starts helped. If I were you I'd just go talk to Devin.
