Will I run rich/lean?
killer1GDSM
151
Apr 4, 2011
Claremore, Oklahoma
Ok, some one tryed to hack my stock MAF, and they took out both honycombs and im think something else idk but it doesnt look right in it.
Anywho i want to switch over the the 2g maf, i know i will need to get the 2g hard pipe and short filter, and 2g to 1g harness. but will i run rich or lean if i do this? i have a full 3" turbo back no cat to a straight through HKS nockoff muffler. also my emissions are capped off, (Oklahoma no need for it).
Thanks, dustin
p.s., if theres a better solution for this anyhelp is welcomed!
You could go with a maft and a gm maf or the best solution is save up $375 and buy v-3 lite which will help optimize your set-up and support future mods if you wish to do so. Also with link you can set it to a 2g maf and will make so much easier to smooth out airflow readings properly.
You will run Lean. Get some 550's, and you will be good That is what I run. I idle a tad rich, but the rest of the numbers are real good
  • Wanted 6 bolt NT water pipe
    • chrisman287
