Will a regular t25 big t28 rebuild kit work with a FP Big t28 ?
v8killer
371
5
Oct 4, 2002
harlan, Kentucky
Just wondering if a regular t25 big t28 rebuild kit will work with a FP Big t28 turbo !
I've never run into this issue. I do know that there are a different width of journal bearing between the Nissan T25 and Mitsu T25, so you must make sure you get the right kit (some of the better kits come with both, the Mitsu bearings are the wider of the two.)
As far as FP using a thicker shaft on their Big T28 for durability, it's highly possible. You may need to buy your rebuild kit directly from them.
    • george bromwell
    • pma1123
    • Sdcryan1
