Will a 92 awd transmission work in a 95 awd talon????
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
Quick question that i tried searching for but what year transmissions will bolt up to the 95 awd system and perform properly. It says it has a 23 spline output shaft which is what my 95 awd talon has but I'm unsure if the 1g with that would work. Im sure it would bolt up to the block because you can swap 6 bolts in a 2g so just wanting to make sure this will bolt up properly.
No, 3 of the 2g motor mounts are on the transmission where as the 1g there is one on the tranny and the other 2 are on the block so it wouldn't directly bolt up without some fabrication involved, if even possible.
