Will 2.5" Intercooler pipes fit on a 93 gsx with abs?
talontsiboy24
868
3
Mar 28, 2009
60457, Illinois
I want to know if 2.5" intercooler piping will fit on my 1993 gsx with abs? i noticed the abs system might be in the way if i use 2.5" piping but im not sure and the intercooler kit i wanna buy for it comes with 2.5" pipes...
Can the abs be completly removed or should i keep it? how much weight savings can it give u? whats so bad about it? i see alot of people telling me that it sucks having abs and with it removed u save weight and can make more power?
OK do you have a side mount? Front mount? If front is it a short route or long route? The abs can be deleted woud save 10-20 lbs. You would need a proportiong valve for a non abs and to make new lines or pull them off a non abs car.
Yea right now i have a sidemount stock intercooler with stock pipes...i wanna get a front mount intercooler with 2.5" pipes but im worried the pipe going to the intake mani wont fit cause the abs might be in the way?
99.9% of FMIC kits have 2.5" piping.
The routing will dictate whether or not it will fit, but with enough fabbing, it will fit.
Or take the ABS out. ;0
Well its a short route intercooler kit that i wanna get but in the pics with the intercooler kit on a 1g it shows it hooked up without the abs but what about when abs is there? is it gonna fit?
