Wierd shifter problem.
b00stedtalon2
1,084
621
Dec 19, 2005
Detroit, Michigan
This for a 94 talon 5spd.
The problem is first and second gear on the shifter are positioned where 3'rd and 4'th are suppose to be. then 3'rd and 4'th are where 5'th and reverse are. The shifter doesn't allow me to go any further to the right to get into 5'th and reverse. Any idea's on how to center the shifter? I can manually put the trans into all 6 gears fine. I took out the center console and looked at the shifter assembly, it looked to be normal.
Anyone have any ideas of what needs to be adjusted at the shifter assembly?
