2G Wideband with DSMlink
mitsumike0
210
47
Oct 13, 2013
Passaic, New Jersey
Alright, im in a toss up right now. Im going to be running aem wideband with dsmlink and im not sure what to do. The downpipe has a bung already welded in before the cat. If I place my WB there, how will I run dsm link with it? I wanted to replace my rear o2 but deleting the cat right now is not an option. Any thoughts?
Put it in the extra bung before the downpipe. Widebands should be 36 inches away from the turbo so that about right.
I have a relevant ? so im poking it in here.
If i want to wire in my wideband o2 into my rear o2, cant i just use the existing wires that are present for the rear o2 and solder them in there? Everything i read says to splice into the wire harness at the ECU at pin##.
The sensor it self connects to the gauge with a harness. Then separately it has a wire used for data logging. The ECU and gauge are much closer to each other than trying to run a wire from the gauge back down to the actual o2. Honestly you can do it however. But why make it harder?
