rabenne
- 1,803
- 843
- Apr 21, 2006
Racine,
Wisconsin
I have a Zeitronix Zt-2 wideband wired into the rear o2 for logging with DSMlink. I also have the narrow band simlation wire hooked up into the front o2 sensor. Recently the wideband has been pegging lean and pegging rich, but the calculated "a/f ratio" in DSMlink wont match it at all... If the wideband is in the correct range for idle (14.7:1) then the calculated a/f ratio will be around 13.1:1. But when the wideband pegs lean for no apparent reason (18.0:1) the calculated "a/f ratio" in DSMlink cycles around 14.7:1.
So what is used to calculate the a/f ratio in dsmlink?
Since I have the wideband simulating the narrow-band why wouldnt the a/f ratio and wideband always match?
Until recently they usually were within .5 of eachother.
I have found a replacement sensor for $60 shipped but I dont want to fix it if it aint broke.
