Wideband kit
That wideband doesn't come with a gage at all but would work pretty well with something like DSMlink that would allow you to log the analog output of the sensor. I assume you can connect a laptop to it for tuning purposes and display the A/F value on the screen but I don't see that it has a way to display A/F with logged RPM values.
If you have somehting like megasquirt or DSMlink I think this will be a fine wideband as you can then log it with everything else for tuning.
If you don't have DSMlink then I think the base setup from Zeitronix would get you more bang for the buck as it will log A/F, TPS, and RPM, (also boost and EGT if you add those sensors) Zeitronix Order Page It's $79 dollers more but you get more out of it.
The LC1 is a programmable unit, you can set it to display for whatever voltage range you want through its software.
I just installed mine, alot of wiring but not difficult, just took awhile to figure out to put the grounds on the ECU bracket's screws (seperate screws for heater and system ground). I'd get the extremepsi kit with the gauge though
I belive you can get the upgraded LC-1 that includes a gauge for A/F. Go on Inovative's web site. FFTEC was selling it with the gauge. You may want to give them a holler.
Thanks guys i have a laptop so im thinking i can monitor the a/f ratios with the software provided right??
After skimming the owners manual found here, LC-1 Manual I would say that yes you can. Plus from their site it looks like you can add several styles of gauges later if you want to.
