Artago
- 2,094
- 31
- Nov 30, 2006
North Vancouver,
BC, Canada
Hi all. I've been wanting to get wideband kit for my car for a while now but I don't know which one to get. I was hoping I could get some suggestions as to which one to get. Let me give you a quick run down of my future plans and requirements and maybe then you can help me pick out my wideband kit. First of my goal for the car is a 350-400 awhp daily driver. Future upgrades will include FMIC, Walbro 255, FIC 850's or PTE 880's, and AFPR. I also plan to get DSMLink. But for the time being I need to get a wideband for the purpose of diagnosis some problems. My requirements for a wideband kit are as follows:
1. Ability to log. Either directly to PC or to on board memory.
2. Ability to log Air Fuel ratio vs RPMs.
3. Kit must have a 2 1/16th gauge. (Or atleast be able to hook up a 2 1/16th gauge)
4. I must be able to hook up the wideband to DSMLink in the future while still being able to use the gauge and original wideband controller with logging.
5. Bang for the buck. I don't want to cheap out but I don't want to spend an arm and a leg.
Ok so that's what I need. I've been looking at the Innovative DB / LC-1 kit and I really like it except for one thing and that's its inability to log Air Fuel ratio vs RPMs (I think). Is there and way to log AFR vs RPMs with the LC-1 controller??? If so, how? If not, would the LM-1 kit be able to do it?
Any suggestions would be greatly appreciated.
Thanks for all your help,
Tom
Tom
If you're getting link you should be able to tap into that with either the 5v uego output or the 0-1v anolog simulated output and log AF vs. RPM that way.
