Wideband help with Maft Pro
blackrosenova40
398
4
Jan 12, 2006
Belle Plaine, Minnesota
I recently bought a Bosch Wideband from Slowboy Racing and I am runnin a Maft Pro using a Map sensor and a Iat sensor.
My question is how do I wire my wideband to my Maft pro? I dont understand the wirng directions that came with my maft pro. It seems the directions tell me to wire the wideband in parralel with the ecu and that doesnt seem correct to me because the ecu cant get a reading from the wideband. I would think it should be wired in series so that the Maft pro can take the input from the wideband and output with a narrow band signal back to the ecu. But it does not seem the Maft pro has a narrow band output. Can anybody help me with this?
I believe you are getting the whole series wiring and parallel wiring confused..
series wiring is when you place a light bulb /motor/switch/resistor etc. right smack in the same path of current.
parallel wiring is
branched off to another object ... so the instructions are correct.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
