gofer
Moderator
- 8,165
- 1,555
- Feb 18, 2006
South Gilbert,
Arizona
Sounds to me like the switch point of the gauge itself is off and if thats the case then buying a new sensor won't fix anything. The switch point of a narrowband 1v o2 sensor is 0.5v = 14.7:1 AFR. Since your WB o2 sensor is a 5v sensor the switch point should be 2.5v but it seems like its cycling around a higher voltage. My AEM UEGO gauge cycles around 2.8v, I just went into one of my logs to see what the voltage was when 14.7:1 was being displayed.
Unfortunately, if this is the case then I don't know what to tell you other than you might consider putting a front o2 sensor back in and getting a bung welded in the dp for the WB. If you plan on ever getting DSMLink then nows the time to do it as well since you can control the switch point and simulate the narrowband signal with the software itself.
