NOMIEZVR4
- 362
- 22
- Nov 5, 2002
Chicago,
Illinois
Relevant Information
97 Talon TSi
Fresh 7 bolt Motor with under 10k miles, 180 compression across the board
NEW 2g knock sensor just installed, snug and I teflon taped the threads
NO boost leaks tested up to 20+lbs
14b@12lbs of boost
TBE with hi-flo cat
Intake and UICP
Walbro 255 FP
I cant post a log, I am viewing timing via MAC scan tool but the car feels like CRAP. 93 octane or 100 octane makes no difference, right around 4000rpms the ECU just PULLS my timing and the car goes absolutely nowhere. Even at stock boost, 9ish lbs the car is just SLOW. The car was equipped with an AFCII but I pulled it out(it came with the car and I wanted to remove all variables that I didn't install), heck I'm even on stock blacktop 450cc injectors.
If im lucky I'll get 8 degress of timing but the car can't even make it to redline in 2nd gear. What else am I missing? I don't know if its worth mentioning but can a slightly loud transmission cause phantom knock? Its not even terribly loud, but I'm running out of options...please help, thanks.
Nomie
97 Talon TSi
14b@12lbs of boost
TBE with hi-flo cat
Intake and UICP
Walbro 255 FP
Nomie
