Which year Dodge Neon has a 420a
Clos_
Apr 28, 2022
Charlotte, North Carolina
Which year dodge neons have the same engine as a 2g Eclipse (420a) and can I use the ignition coils on my 2g from a neon?
None of the neons came with the same engine as the eclipse. The DOHC models have the same short block but engines are not even close to a direct swap to clear up misinformation there.
As far as the coil pack it's going to depend on the year you have. They changed the style of the connector between 96 and 97 from a short connector to a longer connector with 2 alignment slots. It has to be a DOHC car as well. If you're looking thru the junkyard you'll probably have better luck finding one on a 2.4 engine in a stratus, breeze, pt cruiser, caravan as there are not many DOHC neons out there. Find one of those cars as close to the year your car is and then make sure the connector is the same.
FYI If you pull it from a PT cruiser you will have to remove the intake manifold because it sits over the valve cover.
i have a 1996 2g thanks for the information
