Which throttle body Is this
arejaygsx
Nov 11, 2005
Austin, Texas
It has 1 vaccum port
laserspeeddemon said:
Its probably a 1.8L, 2.0L, or some other hyundai 4G family engine. But I'm leaning towards 1.8L
that is a turbo model most likely a 90 it has the small tps
Mine is the same as his, thats why I posted. I was told it was from a 90 GSX. I thought they were all the same.
I got some pictures to show you the difference in TB.
The first picture is a 91 TB, it has 3 on the top on NONE on the side. 2 of them hove hoses, and one hose has been torn off.
The second picture is a 90 TB, the one sitting in my engine bay, you can clearly see two on top, and two ports on the side.
The third one, is a close-up of the 90 TB with a clear shot of the two side vacuum ports.
Definitely not a 90 GSX. Mine has two on the top and two on the front (side). Was going to suggest that it could be a GSX with the 'extra' vac nipples soldered or JBWeld plugged, but the side ports are all wrong, unless those are coolant lines. In one of the pictures, you can see how it has two 'feeders' for vac lines, but only one actual nipple.
Once I get home, I'll check the TB on my Mirage and see... same style as the Colt. Might also be off a 1.6L Turbo Mirage.
