Spoolin95DSM
- 198
- 0
- Feb 7, 2004
Massachusetts
I have my mind pretty much set on Eibach Prokit springs,Which struts do you think I should use with the Prokits?Thanks
Originally posted by heavyD
Uh. 2G's don't have struts. Koni Yellows are probably the best choice because they have more travel and are a better overall shock than AGX & Illuminas.
Originally posted by Groomz
The Eibach Pro Kits are engineered specifically for the KYB AGX struts/shocks. Use AGXs.
Shocks/struts same difference...well anyways so dont get AGX's then?Ill look into Koni Yellows.Any other reccomendations?Originally posted by heavyD
It is common knoweledge that AGX shocks are not a good choice for 2G's. Don't give bad advise.
If I were giving advice my posts would look like yours. KYB specifically lists that Eibach Pro kits are designed for there struts/shocks.
Advice away.
