rocafellafw
- 357
- 0
- Dec 24, 2008
Philadelphia,
Pennsylvania
My car is finally pretty stable and I've saved up enough for my next round of mods. Before I purchase one or the other I'd like to see everybody's choice of parts I'm looking at
I recently made the mistake of buying a o2 dump thinking it would help my creep but I from what I've been reading it might just make things worse. So before I found out the o2 dump would make things worse my original plan was to finish my complete exhaust system while I have everything apart to do the o2 housing:
Forced Performance Exhaust Manifold + Gasket & Studs
EM to turbo Gasket + Bolts
Turbo to o2 housing Bolts
Which came will come to about $360 ish. All which would be added on to a E3B16 o2 dump, Apexi N1 DP and full 3" exhaust.
Last minute I backed out and started to think maybe I should go the fuel system route to just support what I'm already creeping to (18-22psi
) and purchase a SAFC II, some used 580 (650's if deadtime is no issue w.a SAFC) which would be logged with EVOScan + UEGO I already own which should come around to about $385 ish being injectors are going for about 120~. So any opinions or suggestions would be greatly appreciated on which route I should take. Thanks
-Ant
) and purchase a SAFC II, some used 580 (650's if deadtime is no issue w.a SAFC) which would be logged with EVOScan + UEGO I already own which should come around to about $385 ish being injectors are going for about 120~. So any opinions or suggestions would be greatly appreciated on which route I should take. Thanks-Ant
