Resolved Which Plug is this?
javierabrahamgv
88
Mar 31, 2014
Santo Domingo, Central America
Hey guys,
One plug somehow broke and got in the way of one of my belts.
Now, i don't know where that plug goes into, i tried looking but i didn't see anything where it that could go. This is on a 4G63T. Do you guys recognize it?
The previous owner apparently bought a freaking cheap belt "Mitsuboshi" LOL. I am looking into replacing this, is this the accessory belt?
maybe an ABS plug since thats the only stuff kinda on that side of the car that would allow the car to run ok not being plugged in. Everything else would make the car run noticeably wrong i believe.
I think the ABS are on the firewall, i think it might be this one, what is this for? Seems like dual pressure switch, no?
The Power Steering pump is fine, i had a leak recently, i fixed it but haven't been able to clean it jaja
the proportioning valve is on the wall.. the abs unit sits beneath the frame rail in your picture connected to a abs pump or it looks like part of the AC system those aluminum lines indicate that.However no one has AC in a DSM
The belt you question about is the alternator belt, since it runs to the alternator.
I believe the switch in question is the hood switch (for a theft alarm sensor).
http://www.dsmtuners.com/threads/2g-engine-bay-electrical-connections.298047/#post-151528416
It's not the dual pressure switch as the plug color is wrong (black vs. brown), wire colors are wrong, and the other side of the dual pressure switch can't be pulled out as you show in the picture since it's on the AC drier.
Hi Guys,
Haven't been able to do much on this matter as i have been swamped with work. I will start vacations on wednesday though.
I am now inclining towards ABS as i moved the car from parking space yesterday and noticed, it's not really braking, i completed the brake fluid which was at the minimum and it's still the same. You can feel it starts to brake when the brake pedal reaches the farthest point and it's not much.
I accelerated a bit and tried to brake hard, the car was barely braking and it was moving side to side jajaja.
You guys think it's abs?
