which Oil cooler for 50trim?
91_talon_at said:
Is the stock 90 oil coolers sufficient for the Pte50trim? or will i be better off getting an aftermarket one? if so what size cooler?
It's fine. I have an aftermarket oil cooler w/ -6 lines that I got from diamondstarmotorsports. If you do decide to go this route, you will need to get a tap and tap out the holes to fit the standard size npt fittings, it's easy though. Looks great and works great too. Check my gallery and you will see pics of mine.
If you have access to the 90 cooler, go with it though, it's free.
The stock works just fine, upgraded oil cooler is better of course, but the stock will work just fine. 90 of course.
