which inejctor wire is positive
34tftf
37
Mar 21, 2011
Chambersburg, Pennsylvania
I am installing Injector dynamics 1000cc injectors and it requires you to make your own clips, I was just wondering which wire is which and what part of the clip it goes in? the clip has a 1 and 2 beside each hole assuming 1 is pos and 2 is neg?
2 goes to the ECU
The connector coming from the ECU only goes on in one orientation. Look at the side of the injector right where the clip goes, and you'll see a small '+' sign. This is for stock 450cc injectors though.
thank you for that, but on the clip it only has a 1 and 2 for the holes
