Injector wiring, which side is positive?
drivemusicnow
1,444
30
Nov 15, 2004
Germany, Europe
My DSM cd is acting up and not reading in my computer.
I'm trying to figure out which side (passanger or drivers) of the Fuel injector is positive.
IF someone has the wiring colors that would save me some DMM time.
I have an injector circuit malfunction and figure it's probably just the injector wiring.
One of the wires will be black with a colored stripe and the other wire is either yellow w/stripe or blue w/stripe. The set of black wires are the power feed to the injector and pin 1 on the injector. The injector itself doesn't care which terminal is positive and which is negative.
Steve
Well.. the wires that go to the resistorbox are positive.. wires comming from the ecu(trigger) are negative.
But the clips only go on one way.. and the injector itself doesnt care wich way around you do it, since its a simple solenoid.
Check the wires for breakage and see if their rotten or something.
