420A Injector wiring??
Sullbren17
173
Nov 29, 2012
Chadron, Nebraska
I have this wiring adapter piece that looks like there was something wrong in the wiring and i don't know what its called so i don't know what part to look up and the wire on it came out and like i said the plastic is burnt on the wire and it seems to come apart so you can fix it or something but the male peice doesnt come out or it does and i dont know how to take it out to re soilder but anyone know the name of it or part number or away to fix this?
Ok now i feel like a moron because now i remember i took it off of the map sensor not the injector wiring. so do i need that wire unpluged with the turbo in it?
ok can you be little more clear on what you are asking for help with?
I took my intake apart and i found this wiring and i asked the guy that i bought the car from what it was and he said that it was a jumper harness for the map sensor so then its compatible with a aftermarket turbo is this wire suppose to be unhooked?
Ive personally never seen a map sensor tapped into the injector wiring. Typically map sensors are wired into an ecu input so that your ecu can read an exact boost pressure, it can be used with some gauges too i believe. Is there a tuning system in your car? and were you having any injector problems where that was connected? also for your purposes I would take the map sensor out of the injector part of the wiring harness.
No if you look at it closley there is one wire disconnected its just the harness to the map sensor theres no injector wiring is connected to it i just made that mistake but he said it had something to do with putting a aftermarket turbo on it..
