Which Head Studs?
xi Talon ix
238
Nov 24, 2006
Hughesville, Pennsylvania
Which head studs do I want? I have a 1G 7 bolt short block with a 6 bolt head on it. Do I want 6 or 7 bolt head studs? Thanks in advance.
You need the 7 bolt (11mm) head studs because that is what the block is threaded for. The 6 bolt head is drilled for 12mm studs so no modifications should be needed.
After looking really hard for some threads, the best I came up with are these. It's 180 degrees to what you want but they do talk about 6bolt heads on 7bolt blocks here and there. Romeen is right. Disregard what I said. Go with 7 bolt studs instead.
http://www.dsmtuners.com/forums/cylinder-head-short-block/212287-1g-7bolt-head-1g-6bolt-block.html
http://www.dsmtuners.com/forums/bolt-tech/249633-7bolt-head-6bolt-block.html
http://www.dsmtuners.com/forums/cylinder-head-short-block/185625-6bolt-block-1g-7bolt-head.html
