which gear oil for xcase/rear
tarheels23
102
May 15, 2011
struthers, Ohio
Since I live in ohio I dont know which gear oil to get between lightweight or heavy duty shockproof. Someone said the redline heavy duty can only go to 45 degrees, since it gets colder than that here which one should I get?
Why worry about the outside temperature? Manufacturers put what is needed in the rear end of their cars for years designed for all sorts of temperatures. But, if you're all worried about temps, put a trouble light with a 100w clear bulb in it to keep the case warm.
Redline GL-5 gear oil will handle any temp - hot or cold. AMSOIL makes an excellent GL-5 gear oil as well.
Just don't put GL-5 in your tranny. Stuff will eat up the syncros due to the high content of sulpher in the oil.
I live in Louisiana so its hot here LOL
I use redline heavy shockproof in the xfer and diff.
Redline mt90 for tranny.
I'm worried about temperature because I don't wanna go out to my car when it starts getting cold and go to drive it and my transfer case or rear end breaks because the fluid froze.
I already use mt-90 in my tranny and I love it, I would just feel better using redline in my xcase and rear end than using valvoline 80-90w. Just wanted to know which one to get for my temp region
Fluid won't and doesn't freeze up.
CRAP ! I've lived out in the farm in weather 30 plus below in the dead of winter and never had to worry about any oil based fluid freeze. My vehicles still operated with no problems.
Only way any fluid would freeze up if it had water in it to aid in it freezing, but we don't have to worry on stupid stuff like that since water and oil hate each other in the first place.
You' have to be way up north in Purdoe Bay in Alaska in the dead of winter for fluid to think on freezing-might be thick, but will not freeze - which is -60 plus below.
