Which Fuel Injectors Do you prefer??
TaylorGang
90
Dec 24, 2010
Pittsburgh, Pennsylvania
Installing 16G Evo III Turbo with 255 Walbro Pump. I was wondering what Injectors you guys prefer, I was gonna go with some 800cc - 880cc Injectors. Never really noticed all the different brands and im kinda stuck on which ones I want. Im trying to stay under the 400$ range. :thumb:
Agreed ^ FIC ;) but if your already buying or bought link i'd get bigger injectors . you can always use less of the injector you have. but you cant make them grow much more than what they peak at. either way you will have to tune them . just a thought
I agree with doubleclutch99 on this, if you have link already then go ahead an get bigger injectors now and just tune them down with link. That way if you run lower boost and everything now but upgrade the turbo and run more then you won't need to upgrade injectors again. If you have link it's one of those things you can upgrade once and not have to worry about upgrading again unless you decide to run a whole lotta boost.
You're shooting for 500HP on the 16G? Back in the day we would use a 550s with a 16g. But it's also true that you can dial down big injectors with link and utilize the full potential later, although you lose some resolution trying to do that.
Im ordering DSM Link V3 and Injectors at the same time.. Its alright to start the link up when the new injectors are already in correct?
Yes, just do the auto adjust for the injector size so it's ball park and then you need to do your idle tuning to properly get the injectors set. Read over the wiki start [ECMTuning - wiki] so you get a basic understanding before you actually get Link and don't know what to do. There are also some videos that Tom posted to help everyone get set up.
Just get at least 1150cc injectors if you are planning on going bigger or even consider the though of ethanol. Best to buy once.
