Which Injectors/Fuel Pump????
GSTdude98
May 8, 2005
Pittsburgh, Pennsylvania
I asked this question before but unfortunately i only got one respone, so i figured i would ask it again. I have the Greddy 18g turbo along with the 24r front mount intercooler. I am only running around 10psi of boost and i wanted to get around 20 or so. i know before i do that i need new injectors and fuel pump? i was previously told that i should get nothing less then 660s. Is that true? and should i get the 255 or 190 fuel pump? Thanks alot guys :)
just go with the 190, you wont need a fuel pressure regulator and it will be enough fuel for your application. An safc is made by apex (super air flow converter) go to the tech tips section on this site and read all about tuning, piggyback tuning etc. You really need to understanbd what you are getting into BEFORE you install any larger injectors. I would reccomend slapping on a 190 though immediately just for a margin of safety with the 18g.
for the logger, no a local garage cannot do the tuning unless they ahve a dyno (very expensive) and you will ahve to go back and retune every time you add parts. Get the logger, read up all about tuning and start from there. Once you kno what you are doing, and have gotten your car to run moderately well with the 660's, you can go to a dyno to fine tune if you want.
:coy: Ok, i apologize for my post, and I dont do that very often either! :D I'm gonna hook you up with some links really quick:
http://www.dsmparts.com/customer/product.php?productid=545&cat=164&page=1
http://www.diamondstarmotorsport.com/elecparts_files/AFCII.jpg
http://www.dsmchips.com
http://www.roadraceengineering.com/eclfuel.htm
http://www.pocketlogger.com/index.php?pid=plobdii_ss
I hope this helps steer you in the direction you want to be heading. I'll admit, I was kinda teasin ya' a little along with everybody else. I wouldnt of done so if I knew your situation. I've linked you to pictures of a few things I think you need, or things I KNOW you will find useful :cool:
ok perfect, it looks like i got everything i need to know and i think i pretty much got a list put together in my head of the stuff i need. i realy appreciate the help from you guys too. o ya its no biggy if u guys were just playin around, u were just makin me nervous thinking that my engine is gonna blow up soon or somethin haha. but ya thanks again for all the useful tips and suggestions. I guess ill be seeing ya guys around. ill add you to my friends list :cool: :thumb:
o ya by the way. with the pocketlogger do i just plug it into a palm pilot or a laptop or something? and where does the other end go? ECU? thanks
-andy
