Which injectors fuel pump for 20 psi
johnk
402
3
Jan 29, 2003
Worcester, Massachusetts
I want to run about 20 psi I have a 2.5 turbo back and an evo 16g. I am looking at the fuel management package on extreme PSI. Would 550 injectors be run at too high a duty cycle at 20PSI? and will a 190 pump work fine for keeping fuel pressure smooth? I'd rather avoid getting the 255 if I can cause it needs an AFPR. I don't have a front mount yet but it's on the list when I get money.
OK I'll go with the 660s then thx. This is a package deal so I don't get to choose the rx7 fuel pump. I have to pick between the 190 and the 255 walbro units. Is the 190 suficient or should I go with a 255? I want to avoid getting an AFPR if possible.
