2G Which flywheel for XTD stage 4 clutch?
williamdsm
87
Jul 4, 2007
Newfield, New Jersey
Transmission is toast, so I'll be replacing everything down there. Recently came across a huge amount of positive feedback on XTD's stage 4 6 puck unsprung. And for the price, I think I'm sold.
I just need to know which flywheel has the correct step height for this kit? This will be my first clutch job, I've done a ton of research and I feel comfortable doing it.
I wanted to use RRE's "No Name" flywheel. Does anyone know if this is a compatible flywheel for this XTD kit? If not, what else is there? I was interested in RRE's product because they advertise it being a little heavier and stronger than most lightweight flywheels. I've read horror stories with the lighter ones, but I guess there are pros and cons with every aftermarket part.
Any flywheel stepped to the stock step height will work with the xtd. I run mine with an act streetlight and it works great. I don't know much about rre's flywheel, but as long as it is stepped to the stock height, you will be fine.
Thanks for the reply. That's what I was thinking, just wanted to make sure
