Which Engine Harness is this?
DWR-DSM
903
Jul 5, 2008
Schenectady, New York
I was trying to figure out if I could use this harness for my gsx and if this is a 95-96 or 97-99 engine harness. The 99 GSX shell I got, harness was all over the place and they look completely different.
well theres a few key differences between the 95-96 and 97-99 harness
you need to check this circled area
if its a 95-96 it will have 4 plugs, AC plug (which is the longer one) the coil pack plug, cam sensor plug and crank sensor plug.
if its the later years there will only be 3 plugs because the cam sensor plug is on the other side
also what kind of injector plugs does it have?
form the pic it looks like its the later style but the late 96 models came with those also.
from the pic supplied i would say its a 97+ harness buts its hard to tell forsure
