Engine Harness : What Plug is this :(
CPHunter
1,005
Aug 3, 2004
Winnetka, California
ever since i got my car 8 months ago this plug has just been laying there, i had never started the car til today, run a little funny. i don't know if this plug has anything to do with it, It sat by the firewall.
Discrip.
2 Black Wires
pink Inside with 2 little metal things next to it.
when i found it, it was plugged into a Pink Housing that ran with the engine harness,it had a Blue/yellow wire, and a Green/yellow wire. i don't know where this thing is supposed to go, any help would be great thanks guys :cry:
ok
That is your EGR temp sensor plug. It plugs into a connection just to the right of the detaniton sensor plug on Calif. cars.
You can reach it by comming from the right side and reaching behind the intake.
my car smoke a little under accl. not alot just a tad bit. could this be the problem?
No the only thing it is for is to tell the ECU the EGR is working. When mine showed up it there a interminntent CEL and made no difference in engine opperation.
i hate to reply to a old thread but someone please help my car is running horrible and when i was looking in the engine bay i seen the exact same plug that is in the picutre above in this thread not plugged into anything. i no it is for cali cars only for some egr temp but if your car isnt a cali car does the plug just sit there unplugged???? or if i have that plug does that mean i have a cali car and it needs to be plugged in somewhere? please help..
also can a bad knock sensor code 31 casue a car to run horrible and sputter, knock at start up and when oyu press the gas, have no power, and cut out during acceration and shake horrible at low rpms???? i have good compression but the way the car is runnin it seems my engine is ready to blow up
yes a bad knock sensor will deffinatly make your car run bad. and the plug is there on every model due to mass production. hope this helps you out man
it really does man thanks, so that plug will just sit there and doesnt plug into anything if it isnt a cali car
