Where to stick it? (crank breather hose)
prodsm
258
Nov 12, 2002
canada,
I was going to use a fuel filter as a catch can, but my new hard intake pipe does not have the nipple for the valve cover breather hose. When i insert the fuel filter into the line where should the other end go? Facing the ground or re circulate it back into another line??
Thanks
:dsm: :talon:
You could just stick one of those little breather k&n look-a-like thingies on the end of the valve cover fitting. But oil will drip slightly outta it. I'd say just keep the fuel filter on it and route a hose under the car so it drips out down there, kinda like your coolant overflow hose how it just runs down to the bottom of the car.
