Where to get rubber body plugs?
1fast97gsx
4,517
17
Jul 6, 2003
Orland Park, Illinois
I'm not sure if this is the right place to ask this, but I picked up a 2g gsx and it's missing a few of those rubber plugs that are in the floorboards underneath the carpet. I noticed this because I was replacing the carpet, but I don't want water getting into the car and causing damage. I ordered a set of universal rubber grommets / plugs but they don't go up to the correct size. I was hoping a hardware store or auto parts store would have something but no luck so far. Anyone have experience with this or no where I could get them? I know I could just pop them out of a car at a junkyard, but I never have time to go and as cheap as they should be Id rather just buy them.
Jnz tuning and extreremepsi both can get you your oem parts :thumb:
Can someone verify that part number being correct? The description says it's a door plug and there is no picture. I'm looking for the plugs under the carpet in the floorboards. Thanks.
im also looking for these plugs, whenever it rains and i drive through a puddle (it's inevitable with the roads here) i find puddles of water underneath my passenger seat.
I find MR170067 for the floor plugs. These are larger (30mm) in size than the ones mentioned above as well so you might measure the holes to get a rough idea of which is correct.
No idea if they are still available or not, but that's something you can sort out with a dealership, JNZtuning, the site linked above, or wherever you decide to do business. FWIW, I don't find them on JNZtuning or MitsParts, so that may be a hint at something.
If needed, these are also described as 30mm floor plugs from 1Gs and do at least show up on JNZtuning: MU670035, MU670025.
If it's the same size hole as the antenna you could get one of those honda plugs
I tried five times to post a link to my favorite place for buying rubber body plugs, but the darned obscenity filter blocked me again and again. Then I realized that I probably should read the first post, instead of making an assumption based on the thread title.
In short: NVM.
