Where to find T-25 inlet gaskets?
Blk95gs
711
5
Apr 18, 2002
Havre De Grace, Maryland
Pretty simple, I'm replacing a cracked manifold, and don't see the point in not replacing the inlet (manifold-turbo) gasket, and also the manifold-head gasket. I have been looking for hours, and haven't come up with anything.
Anyone know where I can pick one up?
If you are running a t25, chances are you did not ported it. If that is the case, make sure you get the 6cm gasket and not the 7cm one. If you have ported it, make sure you get a 7cm gasket and match it with the port on the turbine inlet.
Yea, it's not ported. I'm just trying to get my hands on an OEM gasket for it. The manifold needs replaced ASAP, and I don't have the money to upgrade the turbo yet. As far as I've seen, no one seems to sell the gasket for the T-25...unless it's the same as the gasket for a 14b/16g etc. I dont think it is, because the flange looks thinner for the T-25.
