1G Where to find front left brake caliper?
Power Stop does make a kit with calipers, rotors, and pads for around $300.
You can also upgrade to 3000GT calipers with the help of an adapter bracket and different rotors. They do require at least 17" rims for clearance, but would provide even more stopping power. You'd obviously need to source those calipers and rotors as well though so you might end up in the same boat as you are now.
You could also try sourcing a rebuild kit and fixing the one you have.
Car-part dot com might help you source them used at a local junk yard. You could try your local parts store and see if they have any luck.
Message dacowgod on here or at Rix Racing dot com, he does not have any listed but if you messaged him he probably does have them.
Good luck!
I bought my right and both rears from rockauto but they do not have a front left awd for the 94. Where could i find a front left brake caliper for an awd 94?
Given the apparent unavailability I would consider a rebuild kit. They're very cheap and it isn't difficult. If the sliders are good and the piston and bore are clean it's relatively easy.
If you read and somebody says you can use 3000gt non turbo or Diamante brakes that is true but they are not identical. The pistons are different size. You can do this but you would need a pair of calipers and an understanding now your brake bias changed. I would not install just one Diamante or 3kgtnt caliper as that would change the left to right bias vs your 94 calipers. Rebuilt kit is under 20$
