Where to buy Fuel Pressure Solenoid
Stealthrida
67
Oct 10, 2005
spotswood, New Jersey
I dont think this has ever been posted, unless i used the wrong key words. Anyway i was just wondering where can i buy a Fuel PRessure Solenoid. Are the dealers the only place that sell them.
Did it throw a check engine light, code P1105 Fuel Pressure Solenoid malfunction? Check your lines vac lines first and make sure they don't blow off. Those lines seem to get worn out over time.
Also check to see when your car is idling if the light dims a bit. If it does then take it out and blow through it and feel the other end to see if air comes through(the metal end is hot if you just ran the car :D). Mine was clogged and was throwing a light that was dimming at idle.
Both of thoses reasons is what caused my CEL. After doing this It has ran fine for 3 months without a P1105 CEL.
    • george bromwell
    • pma1123
    • Sdcryan1
