Where to buy a 3 nipple pressure solenoid?
Jason_99ozGS
152
Mar 9, 2003
St. Louis,
Does anyone have any idea where to get a 3 nipple pressure solenoid. The solenoid also needs to work off of 12V.
Basically I want a solenoid like this:
Which does this:
-Allows a path for boost/vacuum to travel along the red line
-When 12v is applied it switches the boost/vacuum path to this
If anyone can help me please let me know! Thanks :D
If I remember correctly, there was something in the VFAQ a while back where a guy used a vacuum switching valve off of some car in order to set up his multi-stage boost controller. I believe it gave the exact part number, but I haven't seen the page in a while so I don't remember for sure.
aha! I saved the switchable mbc web page on my computer, so I have the part number.
"Vacuum Switching Valve.... I used a part of a GMC...... the part number is "EGR201" the Name Brands on the box are "Borg Warner" and "Select".. (Red/Black/White box).... some kind of ignition product?..... "
There ya go. GMC part EGR201 is a vacuum switching valve usable for this kind of stuff.
Thanks! Someone on a 3000GT board just told me the GM Typhoons use this, but he didn't have a part #. So with the part # I should be able to find it now :thumb:
Also if you still have that webpage saved on your computer can you send me it? IM me on AIM: qaz135wsx or email it to me at [email protected] if you don't mind...
EDIT: Found a place that sells them incase anyone else who discovers this thread is looking for the same thing...
http://www.horsepowerfreak.com/GM_BOSO.asp
