2G Where to buy 17inch gsx wheel center cap?
kengo
50
Oct 17, 2023
Minneapolis, Minnesota
Any link or website or where to buy 17inch gsx wheel center cap? Thanks in advance.
I recently picked up an OEM set on ebay that were 2 1/4 diameter and came with the retainer clips.
haven't installed them yet to test the fitment but they look like they will work just fine. Mine are going into stock 2Ga wheels but IIRC the center caps are the same size on all 2G wheel. Someone will keep me honest if that's not correct.
Let me know when you are done testing putting them on the wheels. I order one from Amazon and it didn't fit so I want to make sure it fits before I buy again. So yes let me know thanks.
Here is the center cap I bought in the past month and it didn't fit. The size is a little bigger. I think the link you give me on ebay might seems to work. But yes let me know if you test yours and it fits then ill buy thanks.
FWIW I’ve bought a lot of things from the quicksilver seller off eBay. Never had an issue.
Also some 3GS have the same 2gb gsx wheels and center caps so that’s always an option if you find one.
-Daniel
they are close but not identical wheels. the centre caps i can believe are the same but the actual wheels arent
